跳转到主内容
HTC Desire 310 Micro USB Port Replacement
你所需要的
    • The video guide will show you how to replace the micro usb port properly. Repeat each step shown in the recording to complete the repair.
结论
2等其他人完成本指南。
Alex Sander
于02/28/17注册
38,219 声望
创作了202篇指南
4条评论
Can’t see a blasted thing clearly. How do you make the pin connections on the motherboard?
Keith Weisberger - 回复
Hello! Please be more precise, the pin connections are already on the motherboard, if you haven’t got one you’ve probably tear them down.
Alex Sander -
Can barely see anything. Camera lense is filthy, picture not in focus and dark. How do you make the pin connections? it appears that you do so only after soldering the rear legs to the motherboard, but I can’t see how you manage it
It would be nice if you had explained what you were doing during the removal. What was that goo you put on it and how did it work to remove the old part?
andrew - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 709
