简介
The loudspeaker is located within the back panel of the device. This makes it relatively simple to access.
你所需要的
Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
即将完成!
结论
另外一个人完成了本指南。
