跳转到主内容
HTC 7 Surround Camera Replacement
你所需要的
  1. HTC 7 Surround Camera Replacement, Back Case: 步骤 1 中的图像 1,2 HTC 7 Surround Camera Replacement, Back Case: 步骤 1 中的图像 2,2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC 7 Surround Camera Replacement: 步骤 2 中的图像 1,3 HTC 7 Surround Camera Replacement: 步骤 2 中的图像 2,3 HTC 7 Surround Camera Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC 7 Surround Camera Replacement: 步骤 3 中的图像 1,1
    • Separate the screen and back cover with the opening tool.
  4. HTC 7 Surround Camera Replacement, Rear Camera: 步骤 4 中的图像 1,1
    • The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
    • The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 152
