跳转到主内容
HP-Pavillion 500-424 PC Series CPU Fan Replacement
你所需要的
  1. HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: 步骤 1 中的图像 1,2 HP-Pavillion 500-424 PC Series CPU Fan Replacement, Central Processor Fan: 步骤 1 中的图像 2,2
    • Lay the tower down carefully on its right side, with the vents pointing up.
  2. HP-Pavillion 500-424 PC Series CPU Fan Replacement: 步骤 2 中的图像 1,3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 步骤 2 中的图像 2,3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 步骤 2 中的图像 3,3
    • Use the flat head #6 screwdriver bit to unscrew the tower casing.
    • Very gently slide the case towards you.
    • Lift the casing up and gently place it off to the side.
  3. HP-Pavillion 500-424 PC Series CPU Fan Replacement: 步骤 3 中的图像 1,3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 步骤 3 中的图像 2,3 HP-Pavillion 500-424 PC Series CPU Fan Replacement: 步骤 3 中的图像 3,3
    • Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up.
    • Remove each screw from the fan using the Phillips head screwdriver bit.
    • Place the screws in a cup, they are very small and can be lost easily.
    • Remove the old fan from the CPU.
结论
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
2等其他人完成本指南。
Amanda Milby
于09/13/18注册
177 声望
撰写一个指南
团队
Pasco Hernando, Team S5-G73, Prince Fall 2018 Pasco Hernando, Team S5-G73, Prince Fall 2018 的会员
PHSC-PRINCE-F18S5G73
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 30
总计 1,687
