跳转到主内容
HP w2216h Video Port Board Replacement
你所需要的
  1. HP w2216h Video Port Board Replacement, Screen: 步骤 1 中的图像 1,1
    • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
    • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
  2. HP w2216h Video Port Board Replacement: 步骤 2 中的图像 1,2 HP w2216h Video Port Board Replacement: 步骤 2 中的图像 2,2
    • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
    • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Video Port Board Replacement: 步骤 3 中的图像 1,3 HP w2216h Video Port Board Replacement: 步骤 3 中的图像 2,3 HP w2216h Video Port Board Replacement: 步骤 3 中的图像 3,3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Video Port Board Replacement: 步骤 4 中的图像 1,3 HP w2216h Video Port Board Replacement: 步骤 4 中的图像 2,3 HP w2216h Video Port Board Replacement: 步骤 4 中的图像 3,3
    • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Video Port Board Replacement: 步骤 5 中的图像 1,2 HP w2216h Video Port Board Replacement: 步骤 5 中的图像 2,2
    • Remove the 4 connectors from the left side of the monitor on the back.
  6. HP w2216h Video Port Board Replacement: 步骤 6 中的图像 1,3 HP w2216h Video Port Board Replacement: 步骤 6 中的图像 2,3 HP w2216h Video Port Board Replacement: 步骤 6 中的图像 3,3
    • Lift the gray tape of the top of the monitor to expose the ribbon cable.
    • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
    • Lift the reflective tape next to the gray tape.
  7. HP w2216h Video Port Board Replacement: 步骤 7 中的图像 1,3 HP w2216h Video Port Board Replacement: 步骤 7 中的图像 2,3 HP w2216h Video Port Board Replacement: 步骤 7 中的图像 3,3
    • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
    • Lift the screen from the screen assembly.
  8. HP w2216h Video Port Board Replacement, Speakers: 步骤 8 中的图像 1,1
    • Remove the tape holding each speakers wire to the screen assembly.
  9. HP w2216h Video Port Board Replacement: 步骤 9 中的图像 1,2 HP w2216h Video Port Board Replacement: 步骤 9 中的图像 2,2
    • Remove the two 8mm Philips #000 head screws on each speaker.
  10. HP w2216h Video Port Board Replacement: 步骤 10 中的图像 1,2 HP w2216h Video Port Board Replacement: 步骤 10 中的图像 2,2
    • Remove the speakers by lifting them vertically from the screen assembly.
  11. HP w2216h Video Port Board Replacement: 步骤 11 中的图像 1,1
    • Remove the cables that connects the speakers to the signal output board.
  12. HP w2216h Video Port Board Replacement, Video Port Board: 步骤 12 中的图像 1,1
    • Remove the single Phillips #000 head screw above the HDMI port .
  13. HP w2216h Video Port Board Replacement: 步骤 13 中的图像 1,1
    • Remove the two 2.5mm hex screws on either side of the VGA port
  14. HP w2216h Video Port Board Replacement: 步骤 14 中的图像 1,3 HP w2216h Video Port Board Replacement: 步骤 14 中的图像 2,3 HP w2216h Video Port Board Replacement: 步骤 14 中的图像 3,3
    • Remove all 8mm Phillips #000 screws holding the board in place.
    • Remove the ribbon cable towards the bottom of the board by sliding the cable away from the board.
    • Remove both wire busses still on the board.
  15. HP w2216h Video Port Board Replacement: 步骤 15 中的图像 1,1
    • Lift the board out of the screen assembly by first pulling the board away from the wall where the ports mount, then upward.
结论
Branflakes222
于03/25/16注册
396 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-1, Miles Spring 2016 UMass Dartmouth, Team 1-1, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 461
