跳转到主内容
HP w2216h Power Supply Replacement
你所需要的
  1. HP w2216h Power Supply Replacement, Screen: 步骤 1 中的图像 1,1
    • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
    • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
  2. HP w2216h Power Supply Replacement: 步骤 2 中的图像 1,2 HP w2216h Power Supply Replacement: 步骤 2 中的图像 2,2
    • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
    • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Power Supply Replacement: 步骤 3 中的图像 1,3 HP w2216h Power Supply Replacement: 步骤 3 中的图像 2,3 HP w2216h Power Supply Replacement: 步骤 3 中的图像 3,3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Power Supply Replacement: 步骤 4 中的图像 1,3 HP w2216h Power Supply Replacement: 步骤 4 中的图像 2,3 HP w2216h Power Supply Replacement: 步骤 4 中的图像 3,3
    • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Power Supply Replacement: 步骤 5 中的图像 1,2 HP w2216h Power Supply Replacement: 步骤 5 中的图像 2,2
    • Remove the 4 connectors from the left side of the monitor on the back.
  6. HP w2216h Power Supply Replacement: 步骤 6 中的图像 1,3 HP w2216h Power Supply Replacement: 步骤 6 中的图像 2,3 HP w2216h Power Supply Replacement: 步骤 6 中的图像 3,3
    • Lift the gray tape of the top of the monitor to expose the ribbon cable.
    • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
    • Lift the reflective tape next to the gray tape.
  7. HP w2216h Power Supply Replacement: 步骤 7 中的图像 1,3 HP w2216h Power Supply Replacement: 步骤 7 中的图像 2,3 HP w2216h Power Supply Replacement: 步骤 7 中的图像 3,3
    • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
    • Lift the screen from the screen assembly.
  8. HP w2216h Power Supply Replacement, Power Supply: 步骤 8 中的图像 1,1
    • Monitor power supplies can be dangerous. Read ifixit's monitor safety guide before working with power supplies.
    • Remove the cables connecting the power supply to the display port.
  9. HP w2216h Power Supply Replacement: 步骤 9 中的图像 1,1
    • Remove the four 8mm Phillips #000 head screws connecting the power supply to the screen assembly.
  10. HP w2216h Power Supply Replacement: 步骤 10 中的图像 1,1
    • Lift the power supply vertically out of the screen assembly
结论
另外一个人完成了本指南。
Branflakes222
于03/25/16注册
396 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-1, Miles Spring 2016 UMass Dartmouth, Team 1-1, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 770
