跳转到主内容
HP w2216h Power Button Replacement
你所需要的
  1. HP w2216h Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 HP w2216h Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 HP w2216h Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  2. HP w2216h Power Button Replacement: 步骤 2 中的图像 1,1
    • Do not pull the screen away to hard, this could snap the power cable.
    • Remove the power button from the top of the plastic frame.
  3. HP w2216h Power Button Replacement: 步骤 3 中的图像 1,1
    • Remove the power cable by carefully sliding it out of it's plug.
    • Check if there is any tear or fray in the cable.
结论
2等其他人完成本指南。
Sadeq Taha
于03/25/16注册
219 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-1, Miles Spring 2016 UMass Dartmouth, Team 1-1, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 856
