跳转到主内容
HP w2216h Control Buttons Replacement
你所需要的
  1. HP w2216h Control Buttons Replacement, Control Buttons: 步骤 1 中的图像 1,1
    • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
    • Remove the four 12 mm Phillips #000 screws on the back panel.
  2. HP w2216h Control Buttons Replacement: 步骤 2 中的图像 1,2 HP w2216h Control Buttons Replacement: 步骤 2 中的图像 2,2
    • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
    • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Control Buttons Replacement: 步骤 3 中的图像 1,3 HP w2216h Control Buttons Replacement: 步骤 3 中的图像 2,3 HP w2216h Control Buttons Replacement: 步骤 3 中的图像 3,3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Control Buttons Replacement: 步骤 4 中的图像 1,1
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Control Buttons Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic buttons from the contacts
  6. HP w2216h Control Buttons Replacement: 步骤 6 中的图像 1,2 HP w2216h Control Buttons Replacement: 步骤 6 中的图像 2,2
    • Remove the wire connecting the contacts to the screen assembly.
结论
另外一个人完成了本指南。
Patrick Aucoin
于03/25/16注册
221 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-1, Miles Spring 2016 UMass Dartmouth, Team 1-1, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 555
