跳转到主内容
HP rp5700 Repair iOS battery Replacement
  1. HP rp5700 Repair iOS battery Replacement, Cover Removal: 步骤 1 中的图像 1,1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Repair iOS battery Replacement: 步骤 2 中的图像 1,2 HP rp5700 Repair iOS battery Replacement: 步骤 2 中的图像 2,2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Repair iOS battery Replacement: 步骤 3 中的图像 1,3 HP rp5700 Repair iOS battery Replacement: 步骤 3 中的图像 2,3 HP rp5700 Repair iOS battery Replacement: 步骤 3 中的图像 3,3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
  4. HP rp5700 Repair iOS battery Replacement, iOS Battery: 步骤 4 中的图像 1,3 HP rp5700 Repair iOS battery Replacement, iOS Battery: 步骤 4 中的图像 2,3 HP rp5700 Repair iOS battery Replacement, iOS Battery: 步骤 4 中的图像 3,3
    • Press tab on the left side of the battery with your finger to release the battery from its position.
    • The battery should pop up out off its socket easily.
    • Once the battery has been removed, the BIOS is reset. Replace the battery back into its socket to complete the reset.
结论
另外一个人完成了本指南。
Alyssa Briones
于01/21/14注册
1,699 声望
创作了9篇指南
团队
Cal Poly, Team 6-23, Maness Winter 2014 Cal Poly, Team 6-23, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G23
4 名成员
创作了9篇指南
2条评论
Hello.
I followed the above steps on an HP rp5700 desktop. Now the computer time and date is set back to 2000. I have entered setup to change date and time. However, the date and time does not change as I navigate date and time…. no change at all. I have changed this before on other rp5700 desktops but this just wont change.
Someone out there HELP.
Regards.
Turk.
turk.gaonnwe - 回复
I did this for my HP rp5700 desktop, but it did not remedy my situation of after start-up, my icons do not show up. Just a blue windows logo screen. The start button is visible, along with the date/time, but nothing else. Let it sit overnight and the same thing is shown the next morning. Is this Windows Explorer related? If so, what can I do to fix it?
rrsull - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,934
