跳转到主内容
HP rp5700 Cover Removal Replacement
  1. HP rp5700 Cover Removal Replacement, Cover Removal: 步骤 1 中的图像 1,1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Cover Removal Replacement: 步骤 2 中的图像 1,2 HP rp5700 Cover Removal Replacement: 步骤 2 中的图像 2,2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Cover Removal Replacement: 步骤 3 中的图像 1,3 HP rp5700 Cover Removal Replacement: 步骤 3 中的图像 2,3 HP rp5700 Cover Removal Replacement: 步骤 3 中的图像 3,3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
结论
11等其他人完成本指南。
Alyssa Briones
于01/21/14注册
1,699 声望
创作了9篇指南
团队
Cal Poly, Team 6-23, Maness Winter 2014 Cal Poly, Team 6-23, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G23
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 77
总计 21,532
