跳转到主内容
HP m8226x Power Supply Replacement
你所需要的
  1. HP m8226x Power Supply Replacement, HP m8226x Power Supply: 步骤 1 中的图像 1,3 HP m8226x Power Supply Replacement, HP m8226x Power Supply: 步骤 1 中的图像 2,3 HP m8226x Power Supply Replacement, HP m8226x Power Supply: 步骤 1 中的图像 3,3
    • Turn off your computer and remove the power cord by pulling it straight out of its socket.
  2. HP m8226x Power Supply Replacement: 步骤 2 中的图像 1,3 HP m8226x Power Supply Replacement: 步骤 2 中的图像 2,3 HP m8226x Power Supply Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws holding the right (from the back) case door to the computer.
  3. HP m8226x Power Supply Replacement: 步骤 3 中的图像 1,3 HP m8226x Power Supply Replacement: 步骤 3 中的图像 2,3 HP m8226x Power Supply Replacement: 步骤 3 中的图像 3,3
    • Remove the side case door by pulling the tab towards the back of the computer with your hand.
    • Pull the door outward to remove it.
  4. HP m8226x Power Supply Replacement: 步骤 4 中的图像 1,2 HP m8226x Power Supply Replacement: 步骤 4 中的图像 2,2
    • Remove the four screws holding in the power supply.
  5. HP m8226x Power Supply Replacement: 步骤 5 中的图像 1,1
    • Lay the computer on its side to make it easier to remove the wiring.
  6. HP m8226x Power Supply Replacement: 步骤 6 中的图像 1,3 HP m8226x Power Supply Replacement: 步骤 6 中的图像 2,3 HP m8226x Power Supply Replacement: 步骤 6 中的图像 3,3
    • Remove the computer processor's power cord by pinching the clip on the connector and pulling it straight out.
  7. HP m8226x Power Supply Replacement: 步骤 7 中的图像 1,3 HP m8226x Power Supply Replacement: 步骤 7 中的图像 2,3 HP m8226x Power Supply Replacement: 步骤 7 中的图像 3,3
    • Remove the power cord from the optical disc drive by pulling it straight out.
  8. HP m8226x Power Supply Replacement: 步骤 8 中的图像 1,3 HP m8226x Power Supply Replacement: 步骤 8 中的图像 2,3 HP m8226x Power Supply Replacement: 步骤 8 中的图像 3,3
    • If the hard drive doesn't have a SATA port connector then move to step 9.
    • Disconnect the SATA port connector from the hard drive by pulling it straight out.
  9. HP m8226x Power Supply Replacement: 步骤 9 中的图像 1,2 HP m8226x Power Supply Replacement: 步骤 9 中的图像 2,2
    • If the hard drive has a 4-pin Molex connector, pinch the two clips on the connector and pull it straight out to remove it.
  10. HP m8226x Power Supply Replacement: 步骤 10 中的图像 1,3 HP m8226x Power Supply Replacement: 步骤 10 中的图像 2,3 HP m8226x Power Supply Replacement: 步骤 10 中的图像 3,3
    • Remove the power to the motherboard by pinching the clip and pulling it straight out.
  11. HP m8226x Power Supply Replacement: 步骤 11 中的图像 1,2 HP m8226x Power Supply Replacement: 步骤 11 中的图像 2,2
    • Remove the power supply by pushing it out from the back of the computer and lifting it out of the computer.
结论
另外一个人完成了本指南。
Scott Fisher
于03/30/16注册
128 声望
撰写一个指南
团队
Michigan Tech, Team 1-5, Lauer Spring 2016 Michigan Tech, Team 1-5, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G5
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 706
