本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
While sliding the silver release tab up, simultaneously lift the cover up from the left side.
Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
Now that the front cover is removed we can detach the screen
Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
另外一个人完成了本指南。
