当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Next, use your plastic removal tool to separate the gray back from the black center piece.
For better results, start the separation at the corner piece.
Next, unlock and remove the ribbon cable.
Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
The bar, the connector, and the cable are fragile components that are easily broken.
Next, remove the wire from the bottom of the mother board.
The easiest method is to use metal tweezers and grip the plug closest to the connector.
Make sure all the connections are properly disconnected before separation from the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
