跳转到主内容
HP iPAQ HW6515 Flash LED Bulb Replacement
你所需要的
  1. HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: 步骤 1 中的图像 1,3 HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: 步骤 1 中的图像 2,3 HP iPAQ HW6515 Flash LED Bulb Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the HP iPAQ HW6515 over with the screen facing down.
    • Take the back cover off by pressing on the small silver button while pulling back then up on the case.
    • Place the back of the case aside for now.
  2. HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling up on the black tab.
  3. HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: 步骤 3 中的图像 1,3 HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: 步骤 3 中的图像 2,3 HP iPAQ HW6515 Flash LED Bulb Replacement, Flash LED Bulb: 步骤 3 中的图像 3,3
    • Unscrew the four screws using the T6 hexagonal star screwdriver.
    • Unscrew the middle screw using the Phillips 00 screwdriver.
    • "Warranty VOID if broken" sticker might be covering the middle screw, if this is the case, peel it off to reveal the screw.
  4. HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 4 中的图像 1,3 HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 4 中的图像 2,3 HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opening tool to pry apart the covers along the bottom of the phone.
    • Slide the plastic opening tool along the seam until the two halves of the case separate.
  5. HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 5 中的图像 1,2 HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 5 中的图像 2,2
    • Unplug the sensor wire that connects the two halves of the case before pulling the two halves apart. Not doing so will damage the sensor wire.
  6. HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 6 中的图像 1,3 HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 6 中的图像 2,3 HP iPAQ HW6515 Flash LED Bulb Replacement: 步骤 6 中的图像 3,3
    • Gently pull off the black rubber square covering the LED light.
    • The LED is now exposed.
    • Wedge the plastic opening tool under the LED to pop it out and expose its wire.
    • Using your index finger and thumb, unplug the wire from the phone and remove the LED.
结论
另外一个人完成了本指南。
Steven Vo
于04/02/12注册
33 声望
撰写一个指南
团队
Cal Poly, Team 15-17, Forte Spring 2012 Cal Poly, Team 15-17, Forte Spring 2012 的会员
CPSU-FORTE-S12S15G17
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,174
