跳转到主内容
HP iPAQ H2200 motherbaord replacement
你所需要的
  1. HP iPAQ H2200 motherbaord replacement, Battery: 步骤 1 中的图像 1,1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 motherbaord replacement: 步骤 2 中的图像 1,2 HP iPAQ H2200 motherbaord replacement: 步骤 2 中的图像 2,2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 motherbaord replacement, Main Board: 步骤 3 中的图像 1,1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 motherbaord replacement: 步骤 4 中的图像 1,1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 motherbaord replacement: 步骤 5 中的图像 1,1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 motherbaord replacement: 步骤 6 中的图像 1,3 HP iPAQ H2200 motherbaord replacement: 步骤 6 中的图像 2,3 HP iPAQ H2200 motherbaord replacement: 步骤 6 中的图像 3,3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 motherbaord replacement: 步骤 7 中的图像 1,2 HP iPAQ H2200 motherbaord replacement: 步骤 7 中的图像 2,2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 motherbaord replacement: 步骤 8 中的图像 1,1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 motherbaord replacement: 步骤 9 中的图像 1,1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 motherbaord replacement: 步骤 10 中的图像 1,1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 motherbaord replacement: 步骤 11 中的图像 1,1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
结论
4等其他人完成本指南。
Tyler Andrews
于01/13/10注册
209 声望
创作了5篇指南
团队
Cal Poly, Team 4-12, Forte Winter 2010 Cal Poly, Team 4-12, Forte Winter 2010 的会员
CPSU-FORTE-W10S4G12
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 20
总计 4,630
