跳转到主内容
HP eStation Zeen Motherboard Replacement
你所需要的
  1. HP eStation Zeen Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 HP eStation Zeen Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 HP eStation Zeen Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the screw caps using the metal spudger.
    • Remove the four 6mm Phillips screws using the Phillips #0 screwdriver.
  2. HP eStation Zeen Motherboard Replacement: 步骤 2 中的图像 1,3 HP eStation Zeen Motherboard Replacement: 步骤 2 中的图像 2,3 HP eStation Zeen Motherboard Replacement: 步骤 2 中的图像 3,3
    • Unclip each side of the back cover by inserting the plastic opening tool and sliding it along the edge.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Motherboard Replacement: 步骤 3 中的图像 1,1
    • Disconnect battery clip with plastic opening tool.
    • The clip is very fragile.
  4. HP eStation Zeen Motherboard Replacement: 步骤 4 中的图像 1,1
    • Disconnect the speaker terminal with the plastic opening tool.
  5. HP eStation Zeen Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect the the volume button clip with metal spudger tool.
    • The clip is fragile.
  6. HP eStation Zeen Motherboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the ground wire from the motherboard with tweezers.
  7. HP eStation Zeen Motherboard Replacement: 步骤 7 中的图像 1,2 HP eStation Zeen Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the two 6mm Phillips screws with Phillips #0 screwdriver.
  8. HP eStation Zeen Motherboard Replacement: 步骤 8 中的图像 1,2 HP eStation Zeen Motherboard Replacement: 步骤 8 中的图像 2,2
    • Pry off the clips that hold the motherboard down with the plastic spudger.
  9. HP eStation Zeen Motherboard Replacement: 步骤 9 中的图像 1,2 HP eStation Zeen Motherboard Replacement: 步骤 9 中的图像 2,2
    • Lift motherboard up to expose the ribbons on the back.
    • Lift the grey tabs to disconnect the ribbons with plastic spudger.
结论
另外一个人完成了本指南。
dalton hale
于09/26/16注册
503 声望
创作了4篇指南
团队
USF Tampa, Team 16-4, Eyestone Fall 2016 USF Tampa, Team 16-4, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 535
