跳转到主内容
HP dv7-4065x Keyboard Replacement
  1. HP dv7-4065x Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the battery from the laptop.
  2. HP dv7-4065x Keyboard Replacement: 步骤 2 中的图像 1,1
    • Move the switch in the battery compartment.
  3. HP dv7-4065x Keyboard Replacement: 步骤 3 中的图像 1,1
    • Carefully flip up the keyboard panel.
    • Don't pull far on the keyboard. It will still be connected to the laptop via ribbon cables.
  4. HP dv7-4065x Keyboard Replacement: 步骤 4 中的图像 1,1
    • Lift the retaining flap on the keyboard cable ZIF connector.
    • Carefully pull the ribbon cable from its socket on the motherboard.
结论
Mikayla Tabora
于03/08/17注册
201 声望
创作了2篇指南
团队
一条评论
First you need to unscrew 2 screws under the HDD cover
christo04 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,599
