跳转到主内容
HP dv5-1125nr WLAN Card Replacement
你所需要的
  1. HP dv5-1125nr WLAN Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr WLAN Card Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr WLAN Card Replacement, Hard Drive: 步骤 3 中的图像 1,2 HP dv5-1125nr WLAN Card Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr WLAN Card Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr WLAN Card Replacement: 步骤 5 中的图像 1,2 HP dv5-1125nr WLAN Card Replacement: 步骤 5 中的图像 2,2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr WLAN Card Replacement: 步骤 6 中的图像 1,2 HP dv5-1125nr WLAN Card Replacement: 步骤 6 中的图像 2,2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr WLAN Card Replacement: 步骤 7 中的图像 1,2 HP dv5-1125nr WLAN Card Replacement: 步骤 7 中的图像 2,2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr WLAN Card Replacement, WLAN Card: 步骤 8 中的图像 1,1
    • Locate the wireless card and the two wires attached to it.
    • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
    • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
  9. HP dv5-1125nr WLAN Card Replacement: 步骤 9 中的图像 1,2 HP dv5-1125nr WLAN Card Replacement: 步骤 9 中的图像 2,2
    • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
  10. HP dv5-1125nr WLAN Card Replacement: 步骤 10 中的图像 1,2 HP dv5-1125nr WLAN Card Replacement: 步骤 10 中的图像 2,2
    • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
    • The card is now free from your computer.
结论
另外一个人完成了本指南。
Cory Mayer
于04/01/14注册
879 声望
创作了2篇指南
团队
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G15
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 1,148
