简介
The motherboard holds the CPU and all connectors that let the computer to connect to the outside world. If something fails on it, like the CPU,sound, or graphics card, the computer is rendered useless until the motherboard is replaced.
你所需要的
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Locate the wireless card and the two wires attached to it.
Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
Remove the CMOS panel cover.
Remove these two 4mm Phillips screws on the back panel using a Phillips #00 screwdriver and remove the cover to reveal the CMOS battery
在这个步骤中使用的工具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Locate the CR2032 watch battery
Using a 2.5mm flathead screwdriver, carefully pry up the battery using the tab to the right of the battery
Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
Locate four 3mm screws in the upper corners of the keyboard tray and remove them using a #00 Phillips screwdriver.
Remove the three 3mm Phillips head screws on the top of the frame using the Phillips #00 screwdriver.
To reassemble your device, follow these instructions in reverse order. Ensure the ribbons and plastic connectors are placed in the correct orientation.
8等其他人完成本指南。
