跳转到主内容
HP dv5-1125nr Keyboard Replacement
你所需要的
  1. HP dv5-1125nr Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Keyboard Replacement, Hard Drive: 步骤 3 中的图像 1,2 HP dv5-1125nr Keyboard Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr Keyboard Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr Keyboard Replacement: 步骤 5 中的图像 1,2 HP dv5-1125nr Keyboard Replacement: 步骤 5 中的图像 2,2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr Keyboard Replacement: 步骤 6 中的图像 1,2 HP dv5-1125nr Keyboard Replacement: 步骤 6 中的图像 2,2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr Keyboard Replacement: 步骤 7 中的图像 1,2 HP dv5-1125nr Keyboard Replacement: 步骤 7 中的图像 2,2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
  8. HP dv5-1125nr Keyboard Replacement, RAM: 步骤 8 中的图像 1,1
    • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
  9. HP dv5-1125nr Keyboard Replacement: 步骤 9 中的图像 1,2 HP dv5-1125nr Keyboard Replacement: 步骤 9 中的图像 2,2
    • Remove the RAM cover to reveal the module's underneath.
  10. HP dv5-1125nr Keyboard Replacement: 步骤 10 中的图像 1,3 HP dv5-1125nr Keyboard Replacement: 步骤 10 中的图像 2,3 HP dv5-1125nr Keyboard Replacement: 步骤 10 中的图像 3,3
    • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
    • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
    • Once the module is released, gently pull the module upwards.
    • Repeat for the RAM module underneath the first one.
  11. HP dv5-1125nr Keyboard Replacement, Keyboard: 步骤 11 中的图像 1,1
    • Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
  12. HP dv5-1125nr Keyboard Replacement: 步骤 12 中的图像 1,1
    • Remove the five remaining 2mm screws using a Phillips #00 screwdriver.
  13. HP dv5-1125nr Keyboard Replacement: 步骤 13 中的图像 1,1
    • Unscrew the 4mm Phillips screw inside the hard drive bay.
    • Make sure to keep track of which screw goes where. The sizes are different for each set of screws!
  14. HP dv5-1125nr Keyboard Replacement: 步骤 14 中的图像 1,2 HP dv5-1125nr Keyboard Replacement: 步骤 14 中的图像 2,2
    • Locate the hole in between the hard drive and RAM compartments.
    • The hole is marked by a small keyboard symbol in the plastic (see the second picture).
    • Unscrew the 4mm Phillips head screw from this hole.
  15. HP dv5-1125nr Keyboard Replacement: 步骤 15 中的图像 1,2 HP dv5-1125nr Keyboard Replacement: 步骤 15 中的图像 2,2
    • Flip the laptop, and use the plastic opening tool on the side seam to remove the top cover.
    • You may need to use the opening tool on both sides of the cover.
    • Be careful not to break the ribbon cables under the cover.
  16. HP dv5-1125nr Keyboard Replacement: 步骤 16 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    购买
    • Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
  17. HP dv5-1125nr Keyboard Replacement: 步骤 17 中的图像 1,1
    • Dislodge the keyboard to access the underside.
    • Do not fully remove the keyboard. It is still attached by a ribbon cable, and forceful removal could break this necessary connection.
  18. HP dv5-1125nr Keyboard Replacement: 步骤 18 中的图像 1,2 HP dv5-1125nr Keyboard Replacement: 步骤 18 中的图像 2,2
    • Locate the ribbon cable connection between the keyboard and motherboard.
    • Pull upwards on the small black bar to release the ribbon cable and remove it.
    • Do not yank on the ribbon or try to pull it out. This may break the cable or motherboard.
  19. HP dv5-1125nr Keyboard Replacement: 步骤 19 中的图像 1,1
    • The keyboard is now ready for replacement.
结论
To reassemble your device, follow these instructions in reverse order. When reinserting the ribbon cable, it should click into place.
2等其他人完成本指南。
Nick Loey
于04/01/14注册
1,676 声望
创作了8篇指南
团队
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G15
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 6
过去 30 天: 27
总计 2,413
