跳转到主内容
HP dv5-1125nr Hard Drive Replacement
你所需要的
  1. HP dv5-1125nr Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 HP dv5-1125nr Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr Hard Drive Replacement: 步骤 5 中的图像 1,2 HP dv5-1125nr Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr Hard Drive Replacement: 步骤 6 中的图像 1,2 HP dv5-1125nr Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr Hard Drive Replacement: 步骤 7 中的图像 1,2 HP dv5-1125nr Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
结论
3等其他人完成本指南。
Nick Loey
于04/01/14注册
1,676 声望
创作了8篇指南
团队
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G15
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 2,051
