跳转到主内容
HP dv5-1125nr Disk Drive Replacement
你所需要的
  1. HP dv5-1125nr Disk Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 1,2 HP dv5-1125nr Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 2,2
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: 步骤 4 中的图像 1,3 HP dv5-1125nr Disk Drive Replacement: 步骤 4 中的图像 2,3 HP dv5-1125nr Disk Drive Replacement: 步骤 4 中的图像 3,3
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
结论
Nick Loey
于04/01/14注册
1,676 声望
创作了8篇指南
团队
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G15
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 733
