跳转到主内容
HP dv5-1125nr CMOS Battery Replacement
你所需要的
  1. HP dv5-1125nr CMOS Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr CMOS Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr CMOS Battery Replacement, CMOS Battery: 步骤 3 中的图像 1,2 HP dv5-1125nr CMOS Battery Replacement, CMOS Battery: 步骤 3 中的图像 2,2
    • Remove these two 4mm Phillips screws on the back panel using a Phillips #00 screwdriver and remove the cover to reveal the CMOS battery
  4. HP dv5-1125nr CMOS Battery Replacement: 步骤 4 中的图像 1,2 HP dv5-1125nr CMOS Battery Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    购买
    • Locate the CR2032 watch battery
    • Using a 2.5mm flathead screwdriver, carefully pry up the battery using the tab to the right of the battery
  5. HP dv5-1125nr CMOS Battery Replacement: 步骤 5 中的图像 1,1
    • The CMOS battery is now removed from your system.
结论
10等其他人完成本指南。
Cory Mayer
于04/01/14注册
879 声望
创作了2篇指南
团队
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G15
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 20
总计 8,442
