跳转到主内容
HP Zbook 15u G2 Hard Drive Replacement
你所需要的
  1. HP Zbook 15u G2 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Zbook 15u G2 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Flip the laptop on its side, and flip the switch at the top so the red side is visible.
    • Slide off the back panel as shown.
  2. HP Zbook 15u G2 Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Zbook 15u G2 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Once the back panel is removed, flip the 2 switches located on the battery so the red is visible.
    • Lift the battery out of the device by pulling up on the tab located between the two switches at the top of the battery.
  3. HP Zbook 15u G2 Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Zbook 15u G2 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • The hard drive is missing from this particular device. The hard drive is located next to the battery as indicated in red. It would normally be enclosed in a metal caddy with a black plastic tab extending toward the battery.
    • Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the drive.
    • Pull the black tab outward in the direction of where the battery was to remove the hard drive from the device.
结论
团队
UMass Dartmouth, Team 3-5, Petersen Spring 2023 UMass Dartmouth, Team 3-5, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G5
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 169
