跳转到主内容
HP ZBook 15 Optical Drive Replacement
你所需要的
  1. HP ZBook 15 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP ZBook 15 Optical Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Optical Drive Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,1
    • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
    • The screw does not come out all the way and stays attached to the computer.
  4. HP ZBook 15 Optical Drive Replacement: 步骤 4 中的图像 1,3 HP ZBook 15 Optical Drive Replacement: 步骤 4 中的图像 2,3 HP ZBook 15 Optical Drive Replacement: 步骤 4 中的图像 3,3
    • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
    • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
结论
4等其他人完成本指南。
Grant Terris
于01/30/15注册
2,828 声望
创作了12篇指南
团队
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G43
4 名成员
创作了15篇指南
2条评论
Mine won't come out and now I think my silver tab is bent. Please help me!
Sajid - 回复
Oddly enough, mine came with no DVD drive but a blanking… thing, which seems to be a trimmed-down version of this official adapter (HP SPS 734298-001) without the electronics. I bought a cheap chinese ODD caddy, tore it down and salvaged the logic board. Luckily, I got everything lined up after a few adjustments (the chinese logic board is a bit longer than the HP one).
Now I’m rocking an extra drive bay without paying the $75 some shops ask for the official one.
I use it as swappable storage (not hot-swappable, mind you) . Very handy for doing drive imaging and cloning when working as an IT technician out in the field.
Luis Alejandro Araúz - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 29
总计 6,783
