跳转到主内容
HP ZBOOK 15 G5 Motherboard Replacement
  1. HP ZBOOK 15 G5 Motherboard Replacement, Opening the Bottom Panel: 步骤 1 中的图像 1,1
    • Find the bottom panel locking mechanism
    • Move the switch to the right to unlock and slide it in a downwards fashion
  2. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Slide the battery latches to the right to loosen the battery
    • Remove the battery and place it to the side
  3. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Keyboard: 步骤 3 中的图像 1,2 HP ZBOOK 15 G5 Motherboard Replacement, Removing the Keyboard: 步骤 3 中的图像 2,2
    • Unscrew the three keyboard screws on the bottom
    • While placing the laptop on it's side, push through the hole to release the keyboard
    • Once the latch releases, flip over the laptop and disconnect the three connectors as well
    • Place the keyboard to the side and flip the laptop over again
  4. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Bottom Case: 步骤 4 中的图像 1,1
    • Remove these screws with a T8 screwdriver
    • Remove these screws with a philips screwdriver
    • Once they are removed, carefully lift up the bottom case
  5. HP ZBOOK 15 G5 Motherboard Replacement, Removing SSD and LCD Connector Cover: 步骤 5 中的图像 1,1
    • Unscrew SSD screw and slide the SSD out
    • Remove these screws and place the LCD connector cover to the side
    • Disconnect all of the motherboard connectors
  6. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Fans: 步骤 6 中的图像 1,1
    • Unscrew all of the screws on the fans (Keep in mind the screw don't come all of the way out)
    • Make sure to disconnect the fan connectors before removing it
  7. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Motherboard: 步骤 7 中的图像 1,1
    • Unscrew the motherboard screws
    • Make sure the SD card holder has been removed
    • Remove the motherboard and place it to the side
    • Place the new motherboard in and screw it into place
    • Screw in the fans and reconnect the motherboard cables
    • Reconnect the LCD connectors
    • Screw the bottom case back onto the laptop
    • Connect the battery and put the battery cover back into place
结论
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
3等其他人完成本指南。
Ved Pitre
于10/30/19注册
1,119 声望
创作了5篇指南
4指南评论
Is it necessary to remove the keyboard if one is just swapping out the fans?
Burtimus - 回复
Answer: No, the keyboard does not have to be removed to swap out the fans .
Burtimus - 回复
My keyboard isn't work how i can remove it and clean it
Ayman Moftah - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 93
过去 30 天: 268
总计 7,759
