Find the bottom panel locking mechanism
Move the switch to the right to unlock and slide it in a downwards fashion
Slide the battery latches to the right to loosen the battery
Remove the battery and place it to the side
Remove the keyboard screws
Remove these screws with a T8 screwdriver
Remove these screws with a philips screwdriver
Once they are removed, carefully lift up the bottom case
Unscrew SSD screw and slide the SSD out
Remove these screws and place the LCD connector cover to the side
Disconnect all of the motherboard connectors
Unscrew the 6 LCD screws to the top left and right
Once removed, carefully remove the LCD
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
另外一个人完成了本指南。
