跳转到主内容
HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement
  1. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement, Access Panel: 步骤 1 中的图像 1,1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 2 中的图像 1,2 HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 2 中的图像 2,2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 3 中的图像 1,2 HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 3 中的图像 2,2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
  4. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement, CPU Fan: 步骤 4 中的图像 1,1
    • Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
  5. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 5 中的图像 1,1
    • Swing the fan upward, to a 90-degree angle.
  6. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 6 中的图像 1,2 HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 6 中的图像 2,2
    • Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
  7. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 7 中的图像 1,1
    • Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
  8. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 8 中的图像 1,1
    • Swing the fan up again and pull it out.
  9. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement, Power on/off Button and HDD Activity LED: 步骤 9 中的图像 1,1
    • Remove HDD activity LED from retaining clip.
  10. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 10 中的图像 1,1
    • Grab and lift the cable off of the motherboard and chassis.
  11. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 11 中的图像 1,1
    • Pull the HDD activity LED out of the chassis.
  12. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: 步骤 12 中的图像 1,1
    • Pull the cable from the motherboard to finish removing the component.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 1,421
