跳转到主内容
HP Z2 Mini G3 Access Panel Replacement
  1. HP Z2 Mini G3 Access Panel Replacement, Access Panel: 步骤 1 中的图像 1,1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Access Panel Replacement: 步骤 2 中的图像 1,2 HP Z2 Mini G3 Access Panel Replacement: 步骤 2 中的图像 2,2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Access Panel Replacement: 步骤 3 中的图像 1,2 HP Z2 Mini G3 Access Panel Replacement: 步骤 3 中的图像 2,2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 45
总计 1,500
