简介
This guide goes over how to replace the controller's trigger button.
If your TPC-Q044 trigger button starts failing when using your controller, you may want to think about replacing the component. The failure may be a result of a loose spring or a broken latch. The replacement of the circuit board is not too complex. You will need the indicated screwdrivers and a spudger to complete this task. There are no warnings or potential hazards when replacing the pad.
你所需要的
Grasp the trigger with one hand while pushing against the outer wall of the shell.
Apply pressure, pulling the wall away from the trigger.
Remove the trigger starting from the freed edge.
4等其他人完成本指南。
