当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Slide the rear compartment cover in the direction of the arrow.
If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
Remove the four 4mm screws using a Phillips #00 screwdriver.
Grip the main body and pull the joystick outwards until the entire front panel pops off.
Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
Use a spudger to pry apart the two halves of the assembly.
Work slowly, prying a small section at a time until the halves are completely separated.
Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
Release the blue flat cable by lifting up the white latch with a spudger.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与3其他贡献者
于01/24/19注册
643 声望
创作了5篇指南
徽章: 13
+ 10更多徽章
CPSU-WHITE-W19S18G5
2 名成员
创作了14篇指南
Where would I be able to buy a replacement small board?
Emerald Wolf - 2019年4月2日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 618
