跳转到主内容
HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement
你所需要的
  1. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: 步骤 1 中的图像 1,3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: 步骤 1 中的图像 2,3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: 步骤 1 中的图像 3,3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Shell: 步骤 2 中的图像 1,2 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Shell: 步骤 2 中的图像 2,2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 步骤 3 中的图像 1,3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 步骤 3 中的图像 2,3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 步骤 3 中的图像 3,3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 步骤 4 中的图像 1,2 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Small Circuit Board: 步骤 5 中的图像 1,2 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Small Circuit Board: 步骤 5 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 步骤 6 中的图像 1,3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 步骤 6 中的图像 2,3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: 步骤 6 中的图像 3,3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
    Any idea if I can buy a replacement ribbion cable
    Randy Pellerin - 回复
结论
另外一个人完成了本指南。
Clement Cheung
于01/24/19注册
643 声望
创作了5篇指南
团队
Cal Poly, Team S18-G5, White Winter 2019 Cal Poly, Team S18-G5, White Winter 2019 的会员
CPSU-WHITE-W19S18G5
2 名成员
创作了14篇指南
一条评论
Where would I be able to buy a replacement small board?
Emerald Wolf - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 616
