跳转到主内容
HP TouchSmart 15-r015dx Keyboard Replacement
你所需要的
  1. HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  2. HP TouchSmart 15-r015dx Keyboard Replacement: 步骤 2 中的图像 1,3 HP TouchSmart 15-r015dx Keyboard Replacement: 步骤 2 中的图像 2,3 HP TouchSmart 15-r015dx Keyboard Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  3. HP TouchSmart 15-r015dx Keyboard Replacement: 步骤 3 中的图像 1,3 HP TouchSmart 15-r015dx Keyboard Replacement: 步骤 3 中的图像 2,3 HP TouchSmart 15-r015dx Keyboard Replacement: 步骤 3 中的图像 3,3
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
结论
2等其他人完成本指南。
Jacob Kleinsorge
于01/30/15注册
2,093 声望
创作了5篇指南
团队
USF Tampa, Team 16-4, Watkins Winter 2015 USF Tampa, Team 16-4, Watkins Winter 2015 的会员
USFT-WATKINS-W15S16G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 25
总计 2,997
