简介
Use this guide to replace the digitizer control board.
你所需要的
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
Remove the two 3.0 mm Phillips screws securing the digitizer control board to the rear case.
Using the edge of a plastic opening tool or your fingernail, carefully flip up the retaining flap on the digitizer control board ribbon cable ZIF socket.
Pull the digitizer control board ribbon cable straight out of its socket on the digitizer control board.
Remove the digitizer control board from the TouchPad.
3等其他人完成本指南。
4条评论
when my charger falled on the screen of my hp touchpad its screen did not break but its touchscreen is not working so which part i whant to change
Beware of the ribbon cable right beneath the volume rocker, as it's easy to shear that cable if you are too rough with the metal spudger.
Michael Innes - 回复
I wasn’t happy with using a metal spudger as it felt a bit forceful, as I have a bulk pack of opening tools I tried using them instead.
I may have been lucky, but by using those tools instead with the angled lip facing inwards at points adjacent to where the mounting clips are located according to the above image (like this, https://i.imgur.com/dylp6BG.jpg ), I managed to open the unit without breaking a clip or scratching the plastic back panel by bending the outside of the panel enough to pop the lcd panel.
Michael Sim - 回复
