跳转到主内容
HP Stream x360 11-p010nr Battery Replacement
你所需要的
  1. HP Stream x360 11-p010nr Battery Replacement, Battery: 步骤 1 中的图像 1,3 HP Stream x360 11-p010nr Battery Replacement, Battery: 步骤 1 中的图像 2,3 HP Stream x360 11-p010nr Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • First, make sure the laptop is completely powered off and not charging to avoid electric shock.
    • Flip the laptop upside down then remove the seven 6.5 mm screws using a JIS J0 screwdriver.
    • Also remove the two 8.5 mm JIS J0 screws near the hinge of the laptop.
    • Peel back the two rubber feet near the hinge of the laptop to reveal and remove two more 8.5 mm JIS J0 screws.
    • The rubber feet near the speakers have no screws.
  2. HP Stream x360 11-p010nr Battery Replacement: 步骤 2 中的图像 1,2 HP Stream x360 11-p010nr Battery Replacement: 步骤 2 中的图像 2,2
    • After removing all the screws, slowly and carefully lift the back cover, exposing the internal components.
    • Be careful not to damage the blue strip when opening the back case.
  3. HP Stream x360 11-p010nr Battery Replacement: 步骤 3 中的图像 1,3 HP Stream x360 11-p010nr Battery Replacement: 步骤 3 中的图像 2,3 HP Stream x360 11-p010nr Battery Replacement: 步骤 3 中的图像 3,3
    • Carefully detach the blue strip that connects the back cover to the internals.
    • Make sure the blue tab is facing upwards when reassembling.
  4. HP Stream x360 11-p010nr Battery Replacement: 步骤 4 中的图像 1,3 HP Stream x360 11-p010nr Battery Replacement: 步骤 4 中的图像 2,3 HP Stream x360 11-p010nr Battery Replacement: 步骤 4 中的图像 3,3
    • Using the JIS J0 screwdriver, unscrew the 6.5 mm screws surrounding the battery.
  5. HP Stream x360 11-p010nr Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the surrounding wire away from the battery
  6. HP Stream x360 11-p010nr Battery Replacement: 步骤 6 中的图像 1,3 HP Stream x360 11-p010nr Battery Replacement: 步骤 6 中的图像 2,3 HP Stream x360 11-p010nr Battery Replacement: 步骤 6 中的图像 3,3
    • Lastly, unhook the clip connecting the battery to the motherboard by pushing it away from the slot.
    • At this point, everything should be disconnected, simply remove the battery. Be sure to maneuver around the wire that runs between the middle of the battery.
结论
5等其他人完成本指南。
Abdulaziz Alkulaib
于03/09/17注册
116 声望
撰写一个指南
团队
USF Tampa, Team S7-G4, Cagle Spring 2017 USF Tampa, Team S7-G4, Cagle Spring 2017 的会员
USFT-CAGLE-S17S7G4
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 14
总计 3,909
