跳转到主内容
HP Stream 8 Speakers Replacement
你所需要的
  1. HP Stream 8 Speakers Replacement, Midframe: 步骤 1 中的图像 1,1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Speakers Replacement: 步骤 2 中的图像 1,1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Speakers Replacement: 步骤 4 中的图像 1,1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Speakers Replacement, Speakers: 步骤 5 中的图像 1,2 HP Stream 8 Speakers Replacement, Speakers: 步骤 5 中的图像 2,2
    • Locate the two speakers at the bottom of the device.
    • Remove the two speakers by prying them out using a pair of tweezers.
    • Detach the red and black power wiring from the device and pull the speakers entirely out of the HP Stream 8.
    • Remember where the red and black wiring is connected to the device.
    • The power wires are soldered to the device and will be difficult to detach.
  6. HP Stream 8 Speakers Replacement: 步骤 6 中的图像 1,1
    • Grab the two replacement speakers and the soldering iron.
    • Locate where the red and black power wiring previously connected to the device.
    • Attach and re-solder the red and black power wiring.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
结论
另外一个人完成了本指南。
Nick Miller
于04/11/16注册
669 声望
创作了6篇指南
团队
Cal Poly, Team 34-14, Maness Spring 2016 Cal Poly, Team 34-14, Maness Spring 2016 的会员
CPSU-MANESS-S16S34G14
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 305
