跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
HP Stream 8 Motherboard Replacement
你所需要的
  1. HP Stream 8 Motherboard Replacement, Midframe: 步骤 1 中的图像 1,1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Motherboard Replacement, Front-Facing Camera: 步骤 5 中的图像 1,1
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Motherboard Replacement, Rear-Facing Camera: 步骤 7 中的图像 1,1
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the motherboard from the device.
结论
另外一个人完成了本指南。
Nick Miller
于04/11/16注册
669 声望
创作了6篇指南
团队
Cal Poly, Team 34-14, Maness Spring 2016 Cal Poly, Team 34-14, Maness Spring 2016 的会员
CPSU-MANESS-S16S34G14
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,067
