跳转到主内容
HP Stream 14-CB174WM RAM Replacement
你所需要的
  1. HP Stream 14-CB174WM RAM Replacement, Lower Case: 步骤 1 中的图像 1,2 HP Stream 14-CB174WM RAM Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Use an opening pick to gently pry up the edge of the rubber foot.
    • Grab the lifted edge of the foot and gently pull it away.
    • Repeat for the other rubber foot.
    • The oils on your skin can damage the adhesive on the rubber feet. Try not to touch the adhesive part of the feet with your hands.
  2. HP Stream 14-CB174WM RAM Replacement: 步骤 2 中的图像 1,2 HP Stream 14-CB174WM RAM Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the eight 6.6 mm screws that secure the lower case.
  3. HP Stream 14-CB174WM RAM Replacement: 步骤 3 中的图像 1,3 HP Stream 14-CB174WM RAM Replacement: 步骤 3 中的图像 2,3 HP Stream 14-CB174WM RAM Replacement: 步骤 3 中的图像 3,3
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the opening pick around the perimeter, prying every couple of centimeters as you go.
    • You will hear "snaps" of the lower case retaining clips releasing.
    • Continue prying around the entire perimeter until the lower case fully releases.
    • Lift off the lower case.
  4. HP Stream 14-CB174WM RAM Replacement, RAM: 步骤 4 中的图像 1,2 HP Stream 14-CB174WM RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • There are spring-loaded metal clips on each side of the RAM stick. Place your fingers on each metal clip and push them to the side.
    • The RAM will lift a few millimeters; this is normal.
  5. HP Stream 14-CB174WM RAM Replacement: 步骤 5 中的图像 1,1
    • Pull the RAM module directly out of its slot.
    • Only handle the RAM by its edges. Skin oils can damage the component and dirty its gold contacts.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 57
