跳转到主内容
HP Stream 13-c002dx Speakers Replacement
你所需要的
  1. HP Stream 13-c002dx Speakers Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Stream 13-c002dx Speakers Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
  2. HP Stream 13-c002dx Speakers Replacement: 步骤 2 中的图像 1,3 HP Stream 13-c002dx Speakers Replacement: 步骤 2 中的图像 2,3 HP Stream 13-c002dx Speakers Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
  3. HP Stream 13-c002dx Speakers Replacement, Speakers: 步骤 3 中的图像 1,3 HP Stream 13-c002dx Speakers Replacement, Speakers: 步骤 3 中的图像 2,3 HP Stream 13-c002dx Speakers Replacement, Speakers: 步骤 3 中的图像 3,3
    • You will notice various screws located on the outer edges of the speakers. Using your Philips screwdriver, remove each of these screws.
    • Connecting the two speakers is a red and black wire located at the edge of the battery. Using your flathead screwdriver, lift the wire upward.
  4. HP Stream 13-c002dx Speakers Replacement: 步骤 4 中的图像 1,2 HP Stream 13-c002dx Speakers Replacement: 步骤 4 中的图像 2,2
    • Using your iFixit Opener Tool, remove the wires connecting the speakers to the motherboard by lifting the indicated piece upward.'
    • A metal spudger is shown in this picture. Use a plastic opening tool to disconnect the connector instead, to avoid damaging the components and conducting electricity.
  5. HP Stream 13-c002dx Speakers Replacement: 步骤 5 中的图像 1,3 HP Stream 13-c002dx Speakers Replacement: 步骤 5 中的图像 2,3 HP Stream 13-c002dx Speakers Replacement: 步骤 5 中的图像 3,3
    • Carefully remove the right and left components of the battery out of the device.
    • You have successfully removed the speakers from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 252
