1. Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components. Flip the laptop over so the bottom is facing up and use your Philips #0 screwdriver to remove the 11 visible 5mm screws on the back.
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up and use your Philips #0 screwdriver to remove the 11 visible 5mm screws on the back.
    • Remove the rubber feet on the bottom of the laptop closest to the screen hinge to gain access to the remaining 2 5mm screws. Keep these screws separate from the first 11.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Flip the laptop back over onto its normal side up and raise the screen. Using the metal spudger, separate the keyboard surface from the bottom of the laptop. While lifting the keyboard surface from the bottom, you will notice 3 cables still attaching them together. Gently unplug each of these cables from the motherboard. With the screen and keyboard parts of the laptop removed, you have access to the laptops internal components.
    • Flip the laptop back over onto its normal side up and raise the screen. Using the metal spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice 3 cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • With the screen and keyboard parts of the laptop removed, you have access to the laptops internal components.
结论
Matthew Dodge
于2018年01月23日注册
324 信誉积分
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 19
总计 175
