简介
对于一个电脑来说,32GB的内存是远远不够的。相对于现在大多数的电脑来说,本次要拆解的产品来说是很容易升级的。经过尝试,可以把内置的无线网卡替换成SSD的方式来对这个电脑进行扩容。作为该产品的拥有者,在经过我自己的尝试后,我发现不论是Win8还是Win10都和该内置无线网卡兼容性不佳。我现在已经把它改造成了一个有250G SSD 存储空间加一个外置无线网卡的设备。阅读本文,你将能把自己的设备改造成和我一样的!
如果有很多人对此感兴趣,我将会不断的更新我的改造。
你所需要的
你会看到一个类似于M.2卡口的插槽但是并不是常规的M.2插槽。可以把无线网卡拆掉更换成mPcie转接卡。当然你也可以购买那些网卡是M.2接口的电脑,这样你就可以接一个M.2 Pcie或者M.2 Ngff的硬盘了。但是就这个而言,你只能使用mPcie转接硬盘了。
将设备重组的时候,反向进行这些步骤即可。
50等其他人完成本指南。
由衷感谢以下译者:
95%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
39条评论
half-width mSATA SSD available in boot?
basicmail3 - 回复
Questo è il problema!!!
Sicuro che tale scheda possa funzionare al Boot del PC.
Bisognerebbe provare potresti dire, 53 $ per la scheda da 64 Gb + 20-30 $ per una penna USB WiFi, tot 80-90 $, e se poi non parte?
bye
That is the question!!!
Sure that this card will work at Boot the PC.
You should try to say, $ 53 for 64 GB card + 20-30 $ for a WiFi USB stick, tot 80-90 $, and if not then part?
bye
Non ci fai vedere come è questa scheda SSD da mettere al posto del modulo WiFi
E poi questa scheda half-width mSATA SSD è possibile farla partire al boot?
E neppure so dove trovarle
Do not you show us how this SD card to put in place the WiFi module.
I've never seen nor know where to find them.
And then this half-width mSATA SSD card, you can start it at boot?
I already have a wi-fi card and I ordered hard drive 120Gb for 53$ . 20 days I'll write how it works or not
Make sure that you order an *PCIe* mini half-width or full-width (buy or make an extension bracket) and you have the current BIOS (HP sometimes whitelists cards).
Be forewarned- Not all mSATA cards will play nice with this slot. I personally recommend the Samsung PM830 128GB SSD HDD Mini PCIe from Amazon for only $40. Word of wisdom, you may have to reconnect the battery for Windows to recognize it.
