跳转到主内容
HP Stream 11-y010nr Screen Replacement
你所需要的
  1. HP Stream 11-y010nr Screen Replacement, Keyboard: 步骤 1 中的图像 1,3 HP Stream 11-y010nr Screen Replacement, Keyboard: 步骤 1 中的图像 2,3 HP Stream 11-y010nr Screen Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Screen Replacement: 步骤 2 中的图像 1,2 HP Stream 11-y010nr Screen Replacement: 步骤 2 中的图像 2,2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Screen Replacement: 步骤 3 中的图像 1,2 HP Stream 11-y010nr Screen Replacement: 步骤 3 中的图像 2,2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Screen Replacement: 步骤 4 中的图像 1,1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Screen Replacement: 步骤 5 中的图像 1,3 HP Stream 11-y010nr Screen Replacement: 步骤 5 中的图像 2,3 HP Stream 11-y010nr Screen Replacement: 步骤 5 中的图像 3,3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Screen Replacement, Screen: 步骤 6 中的图像 1,3 HP Stream 11-y010nr Screen Replacement, Screen: 步骤 6 中的图像 2,3 HP Stream 11-y010nr Screen Replacement, Screen: 步骤 6 中的图像 3,3
    • Using your fingers or a spudger, pull the battery cable from its connector to disconnect power from the motherboard.
  7. HP Stream 11-y010nr Screen Replacement: 步骤 7 中的图像 1,2 HP Stream 11-y010nr Screen Replacement: 步骤 7 中的图像 2,2
    • Insert iFixit opening picks into the edges of the screen to break the seal between the screen and bezel.
  8. HP Stream 11-y010nr Screen Replacement: 步骤 8 中的图像 1,3 HP Stream 11-y010nr Screen Replacement: 步骤 8 中的图像 2,3 HP Stream 11-y010nr Screen Replacement: 步骤 8 中的图像 3,3
    • Peel the hinge up by sliding iFixit opening picks left to right along the hinge.
  9. HP Stream 11-y010nr Screen Replacement: 步骤 9 中的图像 1,3 HP Stream 11-y010nr Screen Replacement: 步骤 9 中的图像 2,3 HP Stream 11-y010nr Screen Replacement: 步骤 9 中的图像 3,3
    • Remove the bezel by pulling upwards on the left bottom corner.
  10. HP Stream 11-y010nr Screen Replacement: 步骤 10 中的图像 1,2 HP Stream 11-y010nr Screen Replacement: 步骤 10 中的图像 2,2
    • Disconnect the screen from the motherboard by pulling the display cable from its connector.
  11. HP Stream 11-y010nr Screen Replacement: 步骤 11 中的图像 1,1
    • Unscrew the four 0.4mm screws surrounding the display using a Phillips #00 screwdriver.
  12. HP Stream 11-y010nr Screen Replacement: 步骤 12 中的图像 1,3 HP Stream 11-y010nr Screen Replacement: 步骤 12 中的图像 2,3 HP Stream 11-y010nr Screen Replacement: 步骤 12 中的图像 3,3
    • Gently remove the screen from its holding and lay the screen down on the keyboard. It is still attached to the computer.
  13. HP Stream 11-y010nr Screen Replacement: 步骤 13 中的图像 1,3 HP Stream 11-y010nr Screen Replacement: 步骤 13 中的图像 2,3 HP Stream 11-y010nr Screen Replacement: 步骤 13 中的图像 3,3
    • Take the tweezers and push up on the small connector to the left of the webcam.
  14. HP Stream 11-y010nr Screen Replacement: 步骤 14 中的图像 1,2 HP Stream 11-y010nr Screen Replacement: 步骤 14 中的图像 2,2
    • Gently pull the cord out from around the screen area.
  15. HP Stream 11-y010nr Screen Replacement: 步骤 15 中的图像 1,2 HP Stream 11-y010nr Screen Replacement: 步骤 15 中的图像 2,2
    • Remove the screen with the display cable attached.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 462
