简介
This guide will show the step by step process of disassembling the HP stream in order to remove and replace the USB port.
你所需要的
Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
Turn the device top down so the rubber feet are facing up.
Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
另外一个人完成了本指南。
