跳转到主内容
HP Stream 11-r014wm Battery Replacement
你所需要的
  1. HP Stream 11-r014wm Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Stream 11-r014wm Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a plastic spudger to remove two oblong screw covers on the bottom of the computer.
    • Use a plastic spudger to remove four rubber feet.
    • To remove the feet you must break the glue seal holding them down.
  2. HP Stream 11-r014wm Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the eleven 5 millimeter housing screws from the bottom of the computer using a #00 Phillips head screwdriver.
  3. HP Stream 11-r014wm Battery Replacement: 步骤 3 中的图像 1,2 HP Stream 11-r014wm Battery Replacement: 步骤 3 中的图像 2,2
    • Turn the computer over and open it.
    • Use a plastic spudger to pry the keyboard bezel away from the base. Pry around the edge, being careful not to jam the spudger too far underneath the bezel (potentially damaging internal components).
    • The bezel is tightest near the hinge.
    • Once the bezel is free, do not lift it away from the base.
  4. HP Stream 11-r014wm Battery Replacement: 步骤 4 中的图像 1,2 HP Stream 11-r014wm Battery Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Identify two ribbon connectors and the ZIF cable underneath the keyboard.
    • Use tweezers to disconnect both ribbon cables and the ZIF connector.
  5. HP Stream 11-r014wm Battery Replacement: 步骤 5 中的图像 1,2 HP Stream 11-r014wm Battery Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove six 5 millimeter screws from the battery.
  6. HP Stream 11-r014wm Battery Replacement: 步骤 6 中的图像 1,3 HP Stream 11-r014wm Battery Replacement: 步骤 6 中的图像 2,3 HP Stream 11-r014wm Battery Replacement: 步骤 6 中的图像 3,3
    • Use a plastic spudger to remove the two power connectors.
    • Lift the battery out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 35
总计 3,816
