跳转到主内容
HP Stream 11-d020nr Lower Case Replacement
你所需要的
  1. HP Stream 11-d020nr Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,3 HP Stream 11-d020nr Lower Case Replacement, Lower Case: 步骤 1 中的图像 2,3 HP Stream 11-d020nr Lower Case Replacement, Lower Case: 步骤 1 中的图像 3,3
    • Before disassembly, unplug and power off the Stream 11.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d020nr Lower Case Replacement: 步骤 2 中的图像 1,2 HP Stream 11-d020nr Lower Case Replacement: 步骤 2 中的图像 2,2
    • Remove the eleven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-d020nr Lower Case Replacement: 步骤 3 中的图像 1,3 HP Stream 11-d020nr Lower Case Replacement: 步骤 3 中的图像 2,3 HP Stream 11-d020nr Lower Case Replacement: 步骤 3 中的图像 3,3
    • Turn the computer upright and lift the screen.
    • Carefully use a spudger to pry the plastic keyboard cover from the base.
    • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
    • Work the spudger around the cover to release the clips attaching the cover to the base.
    • Be patient when removing the cover, as there are many clips and it may take some time.
  4. HP Stream 11-d020nr Lower Case Replacement: 步骤 4 中的图像 1,3 HP Stream 11-d020nr Lower Case Replacement: 步骤 4 中的图像 2,3 HP Stream 11-d020nr Lower Case Replacement: 步骤 4 中的图像 3,3
    • Disconnect the cable connecting the ClickPad to the base.
    • Remove the plastic keyboard cover.
    • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
结论
另外一个人完成了本指南。
Ian Somerville
于03/10/16注册
122 声望
撰写一个指南
团队
USF Tampa, Team 3-5, Wollert Spring 2016 USF Tampa, Team 3-5, Wollert Spring 2016 的会员
USFT-WOLLERT-S16S3G5
5 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 1,588
