跳转到主内容
HP Stream 11-d010nr Daughterboard Replacement
你所需要的
  1. HP Stream 11-d010nr Daughterboard Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Stream 11-d010nr Daughterboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Pry off the two elliptical rubber inserts (one in each corner).
    • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
  2. HP Stream 11-d010nr Daughterboard Replacement: 步骤 2 中的图像 1,1
    • Remove the eleven 5.6 mm Phillips #1 screws.
  3. HP Stream 11-d010nr Daughterboard Replacement: 步骤 3 中的图像 1,2 HP Stream 11-d010nr Daughterboard Replacement: 步骤 3 中的图像 2,2
    • Using an iFixit opening tool, pry open the case to separate the keyboard from the main body.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Daughterboard Replacement: 步骤 4 中的图像 1,1
    • Slowly lift the keyboard as there are multiple ribbon cables that could easily be damaged if lifted with force.
    • Carefully lift the keyboard and locate the three ribbon cables connecting the main body of the laptop to the keyboard.
  5. HP Stream 11-d010nr Daughterboard Replacement: 步骤 5 中的图像 1,3 HP Stream 11-d010nr Daughterboard Replacement: 步骤 5 中的图像 2,3 HP Stream 11-d010nr Daughterboard Replacement: 步骤 5 中的图像 3,3
    • Using your fingernail, lift the flaps on the ZIF connectors that are securing the three ribbon cables.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Daughterboard Replacement: 步骤 6 中的图像 1,1
    • Lift the keyboard out of the laptop to remove it from the device.
  7. HP Stream 11-d010nr Daughterboard Replacement, Daughterboard: 步骤 7 中的图像 1,1
    • Pull ribbon out of daughterboard.
  8. HP Stream 11-d010nr Daughterboard Replacement: 步骤 8 中的图像 1,1
    • Remove the 2 3mm screws.
  9. HP Stream 11-d010nr Daughterboard Replacement: 步骤 9 中的图像 1,1
    • Carefully remove daughterboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 114
