跳转到主内容
HP Stream 11-d008TU Battery Connector Unplugging
你所需要的
  1. HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: 步骤 1 中的图像 1,3 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: 步骤 1 中的图像 2,3 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: 步骤 1 中的图像 3,3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: 步骤 2 中的图像 1,2 HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: 步骤 2 中的图像 2,2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: 步骤 3 中的图像 1,3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: 步骤 3 中的图像 2,3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: 步骤 3 中的图像 3,3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: 步骤 4 中的图像 1,3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: 步骤 4 中的图像 2,3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: 步骤 4 中的图像 3,3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: 步骤 5 中的图像 1,3 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: 步骤 5 中的图像 2,3 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: 步骤 5 中的图像 3,3
    • Locate the white plastic connector on the motherboard
    • Peel back the black tape holding the cable's wires in place
    • Pull the white connector out by puling the white plastic away from the connector
    • Do not grab the connector by the wires
结论
另外一个人完成了本指南。
CONVERSION
于03/07/20注册
1,279 声望
创作了8篇指南
团队
Australia Australia 的会员
Community
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 91
