跳转到主内容
加入维修社区 - 创建账户
HP Stream 11 Pro Thermal Paste Replacement
你所需要的
  1. HP Stream 11 Pro Thermal Paste Replacement, Opening the laptop: 步骤 1 中的图像 1,2 HP Stream 11 Pro Thermal Paste Replacement, Opening the laptop: 步骤 1 中的图像 2,2
    • Remove the rubber feet of the laptop, to reveal the screws.
    • Remove the 7 screws holding the palmrest.
  2. HP Stream 11 Pro Thermal Paste Replacement, The insides: 步骤 2 中的图像 1,2 HP Stream 11 Pro Thermal Paste Replacement, The insides: 步骤 2 中的图像 2,2
    • Use a prying tool to separate the palmrest from the bottom plate.
    • Disconnect the battery. And the connectors for the keyboard and touchpad, from the palmrest.
    • Remove the 2 screws that hold the passive cooling plate.
  3. HP Stream 11 Pro Thermal Paste Replacement, Changing the thermal paste: 步骤 3 中的图像 1,1
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton buds or paper towel, but be careful not to go too hard on the CPU.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
结论
另外一个人完成了本指南。
Simeon Brankov
于11/08/20注册
8,522 声望
创作了62篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 38
总计 994
