跳转到主内容
HP Sprocket 2-in-1 Flash Replacement
你所需要的
  1. HP Sprocket 2-in-1 Flash Replacement, Outer Casing: 步骤 1 中的图像 1,2 HP Sprocket 2-in-1 Flash Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Remove the back cover and any printer paper inside the device.
  2. HP Sprocket 2-in-1 Flash Replacement: 步骤 2 中的图像 1,2 HP Sprocket 2-in-1 Flash Replacement: 步骤 2 中的图像 2,2
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
  3. HP Sprocket 2-in-1 Flash Replacement: 步骤 3 中的图像 1,3 HP Sprocket 2-in-1 Flash Replacement: 步骤 3 中的图像 2,3 HP Sprocket 2-in-1 Flash Replacement: 步骤 3 中的图像 3,3
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
  4. HP Sprocket 2-in-1 Flash Replacement: 步骤 4 中的图像 1,3 HP Sprocket 2-in-1 Flash Replacement: 步骤 4 中的图像 2,3 HP Sprocket 2-in-1 Flash Replacement: 步骤 4 中的图像 3,3
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
  5. HP Sprocket 2-in-1 Flash Replacement: 步骤 5 中的图像 1,2 HP Sprocket 2-in-1 Flash Replacement: 步骤 5 中的图像 2,2
    • Remove four 2.5mm JIS #00 screws from the beige casing.
  6. HP Sprocket 2-in-1 Flash Replacement: 步骤 6 中的图像 1,3 HP Sprocket 2-in-1 Flash Replacement: 步骤 6 中的图像 2,3 HP Sprocket 2-in-1 Flash Replacement: 步骤 6 中的图像 3,3
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
  7. HP Sprocket 2-in-1 Flash Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
  8. HP Sprocket 2-in-1 Flash Replacement, Flash: 步骤 8 中的图像 1,2 HP Sprocket 2-in-1 Flash Replacement, Flash: 步骤 8 中的图像 2,2
    • Using a Japanese Industrial Standard (J) screwdriver (J00 bit), remove three 2.5mm screws connecting the flash circuit board to the housing.
  9. HP Sprocket 2-in-1 Flash Replacement: 步骤 9 中的图像 1,2 HP Sprocket 2-in-1 Flash Replacement: 步骤 9 中的图像 2,2
    • Carefully remove ribbon from the flash circuit board.
    • Remove flash circuit board from the housing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 242
