跳转到主内容
HP Split x2 Rear Cover Replacement
你所需要的
  1. HP Split x2 Rear Cover Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. HP Split x2 Rear Cover Replacement: 步骤 2 中的图像 1,3 HP Split x2 Rear Cover Replacement: 步骤 2 中的图像 2,3 HP Split x2 Rear Cover Replacement: 步骤 2 中的图像 3,3
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. HP Split x2 Rear Cover Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. HP Split x2 Rear Cover Replacement: 步骤 4 中的图像 1,2 HP Split x2 Rear Cover Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. HP Split x2 Rear Cover Replacement: 步骤 5 中的图像 1,2 HP Split x2 Rear Cover Replacement: 步骤 5 中的图像 2,2
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
结论
6等其他人完成本指南。
Ricky Huitema
于09/24/15注册
449 声望
创作了2篇指南
团队
Texas Tech, Team 22-5, Rauch Fall 2015 Texas Tech, Team 22-5, Rauch Fall 2015 的会员
TTU-RAUCH-F15S22G5
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 3,874
